92 z28 K member split!!
Old 11-09-2011 | 06:46 AM
Z28camaro92's Avatar
Default 92 z28 K member split!!
I recently got a hold of a 92 Z28 and found that the k member is split on th passenger side, the split is near the ream most connection point of the lower Control arm. Will a new k member remedy this or will there be issues lining up the bolt holes? What to put a tubular k member. Tubular lower control arms. New springs, and new struts
Has anyone seen or heard of this?
Old 11-09-2011 | 10:03 AM
Really? 20 view and no one has an opinion on this problem? I know it's a pretty much "try and find out" thing, but no one ever heard of this happening? Or happened to you?
Old 11-18-2011 | 10:04 PM
vanquishfist's Avatar
I don't see a problem with a new k-member, as long as there isn't any other damage. Sorry about the lack of response in this section, it doesn't get much traffic. You might want to ask in the third gen section.
Old 11-19-2011 | 07:10 AM
All right thanks a lot
Old 01-13-2012 | 08:24 PM
lightningcruiser's Avatar
i've never heard of one splitting. i bent mine once, and all i had to do was replace it. there was other damage to other parts, and those were replaced as well. i can't imagine replacing it wouldn't fix the problem, but that's kind of an expensive fix.
Old 01-14-2012 | 07:12 AM
I just recently dismantled everything, and turn out I will have to bend back some frame and weld it, it has pulled the bolt through the frame. Hope my aftermarket k member will bolt back up:/
tattoo400
07-01-2012 12:11 AM
cmyhtrod
01-08-2010 05:03 PM
Mraktos
10-30-2007 06:25 AM
enduro400rider
05-27-2006 12:08 AM
Quick Reply: 92 z28 K member split!!
