Yet another wheel/tire question
Old 05-03-2007, 09:23 AM
Celticsfan's Avatar
Default Yet another wheel/tire question
I found a set of tires 255/60/15 and i plan on getting these wheels:http://www.aewheel.com/eagle_alloy_wheels.cfm?id=19
and i found these on ebay will these work w/ those tires?
http://cgi.ebay.com/ebaymotors/POLIS...QQcmdZViewItem?
Thanks
Old 05-03-2007, 09:41 PM
1985RS's Avatar
Default RE: Yet another wheel/tire question
i think the 10 inch rim is too wide for the front. and i dont think it will look that great. the rims would be fantastic on the back however, but the front shouldnt be bigger than 8.5-9". as for the tire size, a 255 is a little narrow for a 10 inch rim, i would go with a 275.
Old 05-04-2007, 12:10 AM
Celticsfan's Avatar
Ok thanks for the reply, how about the same tires size and these: 15/8
http://cgi.ebay.com/ebaymotors/POLIS...mZ140112804944
which size would i need theres a bunch of numbers like:
5X4.75 5X4.5 AND 6X5.5
Old 05-04-2007, 12:25 AM
74454bb's Avatar
May 2007 ROTM
you'll need the 5x4.75 bolt patern, if you can get 15/7 front and 15/8 rear, or go with 15-8's all the way around. the 255/60's will work for the back.
Old 05-04-2007, 12:42 AM
Celticsfan's Avatar
they wont work for the front? reason im asking is theres a decent set of used tires on ebay local to me and i cant afford new tires...
Old 05-04-2007, 01:05 AM
74454bb's Avatar
May 2007 ROTM
I think 255's are to big for the front.
Old 05-04-2007, 01:14 AM
Celticsfan's Avatar
How can i tell?
Old 05-05-2007, 01:07 AM
Celticsfan's Avatar
Well i ordered the wheels now onto tires...any reccomendations like before im on a tight budget but dont wannt to get **** either..
Old 05-05-2007, 01:13 AM
1985RS's Avatar
i think a 235/55R15 would be good for the front, and then 255/60's for the rear like 74454bb suggested, either size wont be too expensive, and a lot of shops will mount and balance tires for free if you buy tires through them
Old 05-05-2007, 01:35 AM
74454bb's Avatar
May 2007 ROTM
235/60 for the front, they dont make 15 inch tires in a 235 55 15. .....A 255/60 15 is a wide tall tire. mostly used foe rear tires. The only yay to tell if it will fit the front is to try it on or find someone that can measure the inside of your front wheel well. I have a 245/60 on the back of mine and it won't fit up front.
Quick Reply: Yet another wheel/tire question
