Wiring question.
So, whats the best way to run 2 wires through the firewall and into the cabin? I Really don't wanna pull the dash apart, and im sure there's a better way. Will I have to drill through the firewall? Advice would be well appreciated. :icon_emm:
well, how big of a wire, and where is it going? usually there are some spots that you can get small gauge wiring into around other openings so that you dont have to drill. if you cant find anything, i would suggest drilling a hole in the front of the floorboard. the passenger side has some easily accessible spots, just check on both side before drilling.
Thanks for the input bro, I ended up slipping to wires in with the interior harness through the passenger fender and coming in through the passenger side kick panel.
