wire pics
can some one send me pictures of the wireing harness with the motor out just looking at how the wires are ran
Considering the countless different setups available stock, and later hacked in, we need more info on what your setup is. Simple carb with HEI distributor?
sorry my bad its for a 305 tpi set up
does this help? https://camaroforums.com/forum/album...pictureid=3098 its my 86. the only non factory wires are the 3 red ones on the driver side. everything else is the factory routing
i was going throught all the pics and saw urs but i would like some close ups if posble my buddys got a 305 tpi in his car but hes being a **** and wont let me pop the hood and take pics
my car is all covered up right now. is there anything specific you need to know goes where?
well i think i got it so i put my motor in but now i got some more ?s the motor and wiring are both out of a 91 trans am.
1. r there 1 or 2 plugs that go to the coil cuz i could only find one 2. the wire for the start how do they run (pics would be great) 3. then on the back of the dist theres two plugs and i could only find one 4. there are 3 plugs right above the plug for the wiring harness by the brake master what are they for |
do you mean directly into the coil itself? there should be two wire i do believe, but im not very sure. there are two plugs that go into the distributor, one is to energize it, the other is for the gauge. for the starter, the hot wire should come from the battery to the top pole on the solenoid, and the wire into the starter should come from the lower pole. there should be one wire that goes to the small pole on the solenoid, and that should be it. as far as those three plugs, im not very sure at all what they would be for.
