What to do, $1000
What to do, $1000
So i have a 91 rs, all primed up. I dont care what it looks like but i just wanna go fast, fast. I have a 305 tbi. My trannys slipping so I must get a new one, thats already decided. My question is how can I get more bang for my buck? A 350 and rebuild it (have a shop so no problem there plus my friends dad restores cars for a living so knows what hes doing) or build the 305 with power upgrades?
RE: What to do, $1000
You should know by know from reading other post on this forum that most are going to tell you to get a 350. I am going to say get a 400! But building a 350 will cost more than a cam and intake for your 305.
If its a grand that you have to spend though a 700R4 (4L60) will eat much of that.
ORIGINAL: Abyliks
about the tranny though, are the t5s any stronger then an auto? thinking about swaping
i plan on swaping a 350 in mine, from what i can tell it seems easy, i was told all you need are the 350 injectors, knock sensors and a 350 chip along with the actual motor, everything else will swap over
I say keep the 305 and get a tpi setup and put it on there, that is where you get the most pop. I did a swap from a 305 tbi to 350 tbi and not so much pop plus later you should be able to just swap and leave the tpi on with a 350. for if you look at the stock numbers the difference in horse power between a 305 tpi and a 350 tpi (non g92) is only 10. Plus it is an option that will boost you 60 hp and that you can use again later if you switch to a 305.
So ur saying just get a tpi setup (vs the tbi) and ill get 60 more horses? If I were to get a 350 I was gonna take out all my computer stuff in my car and just drop in a 350 carbed. Could someone drop me some numbers on the horsepower and prices of a tpi kit for a 305 vs a carbed 350? Thnx. Just tryin to get most bang outta my buck. With the $1000 budget I still need the turbo 350 trans and a buddy of mine has a built one for $250, then I need to get a replacement front right rim for my cragar set ($130)so basically $600 left. Hopefully gonna buy a 4.11 gear set to so. Yeah.
