Water pump change?
Old 11-17-2008, 09:58 AM
350rs's Avatar
March 2008 ROTM
Default RE: Water pump change?
just an FYI. those fans, as small as they are, do A LOT for the cooling of that motor. mine didnt kick in and 300+ degree temps followed soon after. long story short, my engine is a bare block on a stand right now..
if it still runs, start it up and watch the exhaust and obviously look around the water pump for leaks. grab hold of the upper radiator hose and check it for flow. if you feel nothing, its likely a thermostat. i forget off the top of my head if it would be cool or hot at that point, but none the less there will be flow. also while your under there, might as well check for intake and head gasket leaks. just a visual is all you will notice from there, thats where the exhaust comes into play. white smoke is coolant burning, blueish is oil.
thebandit110
70-81 V8 Tech
02-27-2013 12:43 AM
cadmanof50s
09-22-2010 08:38 PM
hatchetman1025
08-04-2008 10:02 PM
ronisace
06-18-2008 11:37 PM
r.serio
11-21-2006 02:46 AM
Quick Reply: Water pump change?
