upper strut mounts
RE: upper strut mounts
I think you have to buy the whole assembly. It looks as if the rubber is all molded to it. Its been a while since I had any apart.
If any one does make a bearing where you can atke the mount apart and rep[lace the bearing and rubber inside I would like to know. I need two! Other than that Monroe makes the whole assemblyfor around $65 each.
I have found my strut mounts on autopartswarehouse.com for $56.00each and for struts I found a new set of all 4 on ebay for $99.99 they are the monroe brand. not too shabby if you ask me. I am all ways looking for parts so I always know the cheapest prices on just about anything with my camaro. hope this helps.
I just got some strut mounts for around $58 each. They are the monroe brand. Well one box was monroe and the other had a different name but I like the other brand. The monroe had one big hole for the mounts and was supplied with fender washers. YUCK! And just an oppinion. I have never had good luck with monroe shocks and struts. KYB's have always treated me well.
ill worry about them probably next spring. Ill rotate the tires. replaced the mount, and redo my alignment. Lucky for me, my dad works for Hunter and i can align all my stuff for free. Includeing tire mounting, balancing, road forceing. I can do it all. hell, i could even turn my rotors and drums for free. I need to replace both of my front rotors though. i noticed quiet a bit of rust on the back of one of them. Musta sat for awhile
