trans question
Old Dec 23, 2007 | 01:05 AM
Coveted Hilton's Avatar
Default trans question
im use to powerglides and turbo 350s.
whut vehicle would i [pull a turbo 400 out of?
2wd pickup?
i was told a turbo 350 or powerglide wont take the 500+hp im going to throw @ it.
tho my old turbo 350 tok close to 400
Old Dec 23, 2007 | 08:01 PM
firebird69racer's Avatar
Default RE: trans question
If built right the TH-350 can handle the HP.
The best place to get a TH-400 is from a truck, The output shaft I think is different from a car , as most of the trucks have the yoke bolted to the shaft and use a slip joint in the middle of the driveshaft not at the trans,I see them all the time in wrecking yards.
If you dont know how to build them yourself then I wouldnt even mess with the wrecking yards and just buy one from a vender that sells them out right. I havent bought any from a vender so I dont know who is good or not.
You will have to change your crossmember, and front yoke,and shorten the driveshaft
I have heard of some building the 200R trans to handle a lot of HP and its an overdrive also
Old Dec 30, 2007 | 02:33 PM
rs91ttop's Avatar
A turbo 400 is stronger in stock form, but a 350 is easier to come by. A turbo 350 takes less HP to spin than a 400. A well built 350 will handle a lot.
Old Jan 1, 2008 | 05:11 PM
microkid's Avatar
March 2011 ROTM
Technical User
a well built later-than-87 700r4 can also handle quite a bit of power. not sure about 500 hp, but ive seen supercharged c4's running a stock 700r4
Old Jan 7, 2008 | 10:56 AM
6426yy's Avatar
3/4 ton 2wd pick ups, suburbans, some vans and a few other HD type vehicles, they have slip and solid mount yokes, the 400 slip yoke is bigger. There is such a thing as a TH375 but there pretty rare its a 400 with a 350 yoke.
Old Jan 10, 2008 | 10:31 PM
Dougs1990rs's Avatar
if you are looking for a th400i got one for sale. but warning you it needs to be rebuilt and it's worth $200.
Bluegixxer1k
Jul 27, 2011 08:07 PM
Cappi
Apr 1, 2010 12:04 AM
sikorski
Feb 14, 2010 04:16 PM
edog2
11
Oct 27, 2009 03:59 AM
aggressive327
Mar 1, 2007 07:51 PM
