Tranny questions
I am buying a 350 very soon here and the guy thats selling it to me said that it comes with the transfer case...well i plan on keeping it a fivespeed so will i need the transfer case...and what is the diffrence between a transfercase and the bell houseing? Sorry just looked up the deffinition....so yeah it is coming out of a truck so i wont need the transfercase...i have found a bell housing for a 350 online so i have to buy that yet also. and all of the clutch items
Last I checked, a transfer case is used to dirrect power to the front and/or rear wheels in a 4x4 setup, but it could be some inacurate name he's picked up from someone who didn't know what they were talking about, or didn't know what something's s'posed to be called....
since we are on the topic of transmissions... i think my syncronizer (spelling sucks so bear with me)is going out... When i come home, i back into the shed i park it in. Ill pull up, come to a COMPLETE stop, then try and go into reverse and i grind them like CRAZY! Also i have noticed its sometimes difficult to swith gears, sometimes its switching at all, sometimes it just between one or two gears... any ideas?
It's more likely a bad slave cylinder than a clutch, especially on such an old car. If the fluid is low, check for leaks, as the slave cyl. is MUCH easier to install than a clutch, at least on most cars. Never done it on a Camaro, but they are pretty easy to work on, and I doubt this will be an exception. If the fluid is low, however, it just takes standard DOT3 or DOT4 brake fluid. NEVER a petroleum or silicone based fluid, as the petroleum will swell the rubber seals, and the silicone won't absorb water the way the glycol based DOT3 and DOT4 will, which leads to corrosion. My guess to what happened is that your clutch fluid became saturated, and eventually water settled in the lines and caused it to start rusting out, since brake fluid only absorbs about 6% of it's weight in water.
well the master was a little low, about a half inch. so i filled that up. I havent checked the slave yet as i was a bit to lazy and didnt have enough time to do this... but i will try and do it soon.
