tranny problems
Old Oct 13, 2009 | 11:11 AM
miclo88's Avatar
Default tranny problems
when i crank my car in the mornings she wont go like she should like its got jetlag or something but once its warm she runs fine i was just wondering is there anything i can do about that rebuild the tranny or something? and shes starting to slip when i go around a sharp turn any help is much appreciated Thanks
Old Oct 13, 2009 | 03:07 PM
Are you saying when the engine is cold, the rpm's climb a bit but the car hardly moves? And it does the same thing in a turn? Then your transmission is slipping and is on it's way out. If yours is slipping like that, the clutches are badly worn and a rebuild/replacement is in your future. For what it's worth, I have a friend who's trans acts like that, and he puts in an additive made to help prevent slipping. (drain a quart of fluid and put in the additive) It has bought him well over a year of time and still going, but he has to keep adding more like every six months. When the trans starts slipping that badly, it's at the point of "got nothing to lose".
Old Oct 14, 2009 | 06:21 AM
miclo88's Avatar
yeah thats pretty much it but when i take a turn it completly lets go and just revs without pulling. but im going to get a rebuild kit its only $30 at autozone and after i rebuild it im going to keep that lucas oil in it for every fluid change. Thanks
Old Oct 14, 2009 | 08:21 AM
What rebuild kit for $30 would that be? And have you ever rebuilt an auto trans before? It takes certain knowledge, skills, and tools.
Old Oct 14, 2009 | 01:05 PM
Jr. Mechanic's Avatar
August 2009 ROTM
$30 dollars would be only seals (soft parts.)
Old Oct 14, 2009 | 01:17 PM
have u checked the fluid level? could be sucking air on the corners if its low.
Old Oct 14, 2009 | 07:06 PM
ScottD's Avatar
Two separate problems....
My ole Trusty Volare did the 'turn' thing to me years ago......I thought my tranny was on the way out and got very upset. She was just low on fluid. One quart later she was running fine. Never had a leak or anything. Tranny monster must have stole it. (tranny monster...huh huhhhh)
The 'not running right when cold' is a choke/carb issue. What kind of fuel system are you using? If its carbed, Ill bet you dollars to donuts your choke is filthy and not workin correctly.
Old Oct 14, 2009 | 07:54 PM
microkid's Avatar
March 2011 ROTM
Technical User
i second the low fluid. the fork lift at work does the same thing, as does the back hoe, both automatics. check the fluid with it hot and RUNNING on a level surface. also take note of the color
Old Oct 15, 2009 | 09:14 AM
miclo88's Avatar
No ive never done it before but my neighbor owned a trans shop in Tennessee and he said he would show me how to do it
Old Oct 15, 2009 | 09:15 AM
miclo88's Avatar
This is everything that comes with the $30 kit
Filter, intermediate brake band, 2 tang, 3/4 friction .080" (20 teeth), forward friction .078" (41 teeth), low and reverse friction .087" (25 teeth), overrun friction .078" (36 teeth), reverse/input friction, extension bushing, low and reverse steel .068" (17 t), gasket kit, pump bushing, 3/4 steel .077" (15 teeth), forward steel .078" (20 teeth), reverse input steel .078" (36 teeth), overrun steel .092" (10 teeth) *** Call 1-800-268-2368 for application verification and delivery time before ordering ***
