Takin off the heads of my 350
I have just a early 90's gm 350 motor and i am going to be taking off the heads in the next week. i have been reading up and it is some process taking off the bolts in a set order and what not. can anyone please give me some knowledge or maybe a site that shows the patterns on taking off and putting on with the right torque settings and all. thanks all.
yea i didnt even think about that. thats a great idea. the only problem that i may come across is that i have an 84 z but the motor is a 350 pulled from an early 90's firebird i believe. should all the numbers and settings be the same?
Hey I dont wanna sound like a wise ***, but pulling heads is no novice job......installing them correctly may even require torque to yield bolts and a TTY gauge. If you dont know what sequence to put them back on, you are going to need (at the very least) a chiltons manual and a decent torque wrench. Pulling heads is no small task, and its not a job you want to do over again because you didnt clean a mating surface right or forgot to torque those bolts an extra 15'.
Why you pulling them?
yea the more i been talkin to people and readin up on it i see how much is involved, between takin the distributor cap off and all. the engine has been sitting for some time and is in need of valve stem seals. i have heard it can be done with the heads still on but i wasn't sure if that was easier or not.
You can replace the seals with the heads in place, but you will need an air compressor to pressurize the cylinder and keep the valves from falling in. Or.. you can do it the red neck way by stuffing clothes line into the cylinder through the spark plug hole until the combustion chamber is full.
if the engine from the bird was 92 or older, the manual will have the info on that. all engines from 82-92 are covered in there, with each idividual specs for each engine if there are any differences
Given your limited experience with this car, I suggest you have an experienced mechanic determine if you need valve seals or possibly more. IF you just need the seals, you may choose to go the compressed air method, its not terribly difficult, but you will have to reset the load on the pushrods, which is a art all to itself.
