t-top pins
t-top pins
i recently was given a set of glass t-tops but they have the small pin and my 92 has the large pin. so i was wandering if anyboby knew if the pins can be changed out
thanks
Brad
thanks
Brad
The pins are a part of the latching mechanism and would be a lot of work to change it over. It would be a lot easier to replace the pin receivers that are screwed to the roof, front and back of the top openings. You'll probably be able to find them on ebay.
