Suspension Rates ???
Gidday,
Im not sure whether or not this is the right place to post this or not.[&:]
I'm after the suspension rates for physic's for a 1984 Chevrolet Camaro Z28 for RACER (www.racer.nl / www.racer-xtreme.com http://forum.rscnet.org/forumdisplay.php?f=111 ) which uses real life physic's for the cars handling. I have found almost everything I need to complete it, that is all bar the suspension, I have the travel amounts, but I have been unsucessfull in finding the shock rates ( front and rear ) and spring rates ( front and rear ) and also sway/antiroll bars for it. And the hardest part but not completly nesscary is the Geometry for the suspension.
Im specifically after the 1984 Z28, but seeing as the information is hard to come by I will take anything that comes[8D]
http://img214.echo.cx/my.php?image=exxxtt28qx.jpg
http://img214.echo.cx/my.php?image=inteerriorr8by.jpg
http://img214.echo.cx/my.php?image=exxxtt0bd.jpg
Also if you have any nice V8 sounds such as the starter , and also the engine at a constant RPM that would be much appreciated too as they can be used for the sounds
Cheers,Chris
Cheers,Chris
