Strut caps
I finally took a moment to lok at my strut caps/bearings/bushings, What ever you would like to call them, and noticed that is where the clacking noise is coming from. Any one know where the best price on apair can be found? I used to not care but now that I am on a limited income of mostly zero dollars I need to watch what I spend. And yes to those of you wondering that means I can only put singles any morein the G strings or half naked women with silicone boobies! [&o]
Whoa...that doesnt make em bad gurls.....nevermind, I like bad gurls.....
Those strut caps will run U about 85 bucks a pop, new, from VatoZone. Then you must understand that an alignment might be necessary. Look at your local junk yards....if the bng spins and doesnt hang up, you are fine. 10 bucks a pop...spend the savings on an alignment and strippers.......
I found a pair for $139 but that is still out of my price range. The weather is getting cool so it looks like I will hit up the pick-a-part. Its just the last time I went out there was when I picked up those wrong grills and those A-holes were so expensive on everything anymore. There is not much savings from pulling it yourself with them anymore.[:@]
strut mounts for any car are expensive. plus you will need an alignment. the one thing you have to think about is what kind of driving you do. minor road racing or daily driver stock will do. alot of road racing i would spend the money and buy some aftermarket fulley adjustable and have a custom alignment done with negative caster and camber.
