Still have issues
OK, I still can't figure out what's up with the '82... (305 motor, 200c tranny) It acts almost like there's a rev limiter on it (which there's not) at first, but if I leave the throttle open then it just bogs and slowly dies. Tried un-hooking the lockup to see if it was just being sporadic, nothing; checked the compression of the motor, all good. The valve springs are good, no broken ones, everything is tight on the motor. The exhaust manifold heater valve thing (not sure of the exact term, the valve that get the exhaust manifold to heat up faster) wasn't hooked up to a vacuum source, hooked it back up and it does a little better but still have the problem. I'm pretty much out of ideas here, what the heck is wrong with my car??? Please help! I chose this car over my '75 when I had to sell one, I'd like it to work properly. Oh, it makes it to about 3250 rpm at part throttle and 4000rpm WOT before it starts lugging...
Oh, I forgot to mention that it wont do it until I've driven it for about 3 minutes if it's already warmed up, 6 minutes if it's cold, I timed it. I'll check the fuel lines, think I should run a fuel injector cleaner through it?
The exhaust flows well (well, as well as it should for crappy stock exhaust), and there aren't any obstructions that I can find in it. I'm planning on popping dual exhaust on it soon though so if it is, it wont be for long.
Hmmmmm, I'm thinking I'll cut the cat out anyway....
K, we've got a fuel pressure guage, I'll check all of it. The fuel lines had a bunch of rust in them when I first got a hold of it, maybe it's jsut clogged lines? the fuel pump was replaced when they put the junk motor in it...
ORIGINAL: bobarian91
It's carburteted, but the choke has been torn off since it never worked to begin with. I have the Holley that came with the car that needs to be rebuilt, it has a rebuilt Q-jet from my dad's '78 truck on it now. It DID improve once I put the Q-jet on it...
I'll also note that the motor was installed by Pep Boys... and I've had to go through and tighten everything from the oil filter up to the intake manifold so I'm not sure what else may be loose. It didn't have a breather on it either, that's real good for it... so if there might be something loose causing it then let me know any ideas.
