sluggish response
Old 11-16-2006, 01:45 PM
JoshZ28's Avatar
Default RE: sluggish response
.............now my battery is dead. and its raining.
fun stuff
Old 11-16-2006, 02:01 PM
T10wheels's Avatar
There's an article in "Engine Masters" I think you should read, it's titled "Hate Me". It's about building a 305 up. They get over 370 hp from it and it's with reasonable mods.
Old 11-16-2006, 06:23 PM
MadMikeZ28's Avatar
ORIGINAL: JoshZ28
sluggish as in my co workers stock 87 honda whooped that a$$
and so does my inline 6 wrangler
2000 mercury mountaineer
93 ford taurus lol
it goes on
Well if yours is that slugish I dont think it is because it is a 305. I think it may need some fine tuning and adjusting. Plus you can not always blame the motor. Your rear gear ratio will have an affect on how quick and fast your car is.
Old 11-16-2006, 08:34 PM
JoshZ28's Avatar
i was having a conersattion about the gear ratios with someone today.
i think its gonna be alot in the tuning it runs fine smooth etc. but you floor it and nothing really happens at all
the engine was changed over to carborated im assuming no1 took the time to tune the car to accomodate the change.
itll be a slow on going hobby either way
i originaly wanted a 93-to 97 rs to put a 350 in rather than a 84 z28 but ill see how this goes. i love the look of it
Old 11-16-2006, 11:03 PM
ScottD's Avatar
Floor it and nothing happens? Is your tranny kicking down?
Old 11-16-2006, 11:04 PM
MadMikeZ28's Avatar
The 84s are carbed and a good working, adjusted carb works out well. Thats where the AH and G hanger comes in. Assuming you have the Q-jet the AH are secondary metering rods and the G hanger is what they attach to. They are very simple to change.
Old 11-17-2006, 01:22 AM
FlufyTiger's Avatar
I would look into a clogged exhaust, as that's what it sounds like to me. Get yourself a vacuum gauge. Every mechaninc should have one anyway. Hook it up to the brake booster line (without the vac retention valve in place) and turn the car on. You should have 17-22 inhg (inches of mercury) of vacuum, then snap the throttle open quickly, the gauge should drop to zero inhg, if it goes down slowly, you've got a clog in the exhaust. The catylitic converter is probably the culpret if there's a clog, but you should check the whole system. It's not a sure thing, but what you describe seems like a clogged exhaust.
Old 11-18-2006, 10:59 AM
JoshZ28's Avatar
thanks yall imma start trying different suggestions
darkdesirecamaroman
82-92 V6 Tech
15
05-29-2011 11:18 PM
98maro
01-15-2008 01:03 PM
Mr.Locs
06-12-2007 11:13 AM
dzroc
11-03-2006 01:31 PM
Quick Reply: sluggish response
