Should i continue???
i bought this 1991 Camaro from a guy down the road a little while ago. I was wondering, based on the pictues should i continue with this project or should i buy another camaro and use this car as a parts car.Ok heres what happened(as i was told).......... he hit a telephone pole on the driver side idk how fast but it beat that side of the car pretty good. It looks to me like the whole driver side of the car was rammed a couple of inches back( as in the door picture, the door won't close all the way it overlaps) also he said it cracked the rim on the driver front side so i am not sure what could be wrong with the suspension arm or not. the tires would need to be aligned very bad! so i was just wondering if i should keep going or if i should get another camaro. Thanks
[IMG]local://upfiles/4787/2FE50E391FAC40E7B0602CDAA850BF76.jpg[/IMG]
[IMG]local://upfiles/4787/AD9CF47D2C07477EB676864191E15FAA.jpg[/IMG]
[IMG]local://upfiles/4787/5E5D06512CC249B7A44E0C12BDA190E6.jpg[/IMG]
[IMG]local://upfiles/4787/B5A8B39B357A40118DCEF8625F0D5303.jpg[/IMG]
RE: Should i continue???
in my opinion, unless your looking to put ALOT of time and money into it, i would start with a different car, and use the GOOD stuff from this one to fix BAD things on the other. But thats my opinion, yours may differ.
Everything is doable, the question is how much money do you want to spend. A professional shop MIGHT be able to straighten it, but it'll cost a lot of money, and it'll never be perfectly straight again. So as stated before, use that one as a donor car.
