Radiator Fan Relay Connector
Anybody manage to locate a new connector pigtail for the Radiator Fan Relay?
Been searching all evening and can't track one down. Fan relay went and it melted the connector with it.:eek: Would like to put it back to original condition if I can find the connector. |
just go to the bone yard and get one. I'm sure they are aplenty.
Just for the heck of it, try acdelco tech connect. They had a lot of the pigtails needed for my engine swap that I couldn't find anywhere else. The tech connect site will just give you part numbers, but any auto parts supplier that deals mostly with delco (factory motor parts, carquest....) will have no problem getting them.
Already been to the junk yard, unfortunately it must be a common failure. Each one I checked look like someone had taken a torch to it.
Thanks for the suggestion djs383, hadn't heard of acdelco tech connect. They didn't have it either, but I bookmarked the site since it had a lot of really good stuff on it. Guess I may have to upgrade to an$80 aftermarket setup. So much for keeping it stock... |
deleted
