radiator
Old 07-06-2010, 12:57 AM
1983camaro4life's Avatar
Default radiator
I currently have a V6 in my 1983 camaro. Im not quite sure exactly what size but its a V6. But i am droping a 350 into it. Am I going to have to get a new radiator?
Thanks for the help!
p.s. IF there isnt enough info here let me know what u need to know.
Old 07-06-2010, 06:52 AM
blackz87's Avatar
Yes, I would relpace that 27 yr old radiator. The inside and cooling fins have to blocked with crud. I was shocked to see the front of mine when I replaced it. 40% of the front coolng fins were blocked with heavy crud, because you can't see the front part..
Old 07-06-2010, 11:26 AM
ThirdGenCrazy's Avatar
Hmm. That makes me want to go check mine when it gets back from the transmission shop.
Old 07-06-2010, 12:13 PM
carguy68ssrs's Avatar
Just buy a new one, the biggest v8 radiator,bolt right in
Old 07-06-2010, 12:14 PM
blackz87's Avatar
The way the radiator is covered on these cars the front is hidden. When I had mine replaced due to a lower leak and seen all that curd especially behind the a/c condenser. I knew I found the cooling problem I was chasing for years. I hosed down that area quite often, but it did not help.
No problems now with the new radiator even with the a/c running 100% and it has been over a year now.
My opinion now is this could be the cause of numerous cooling problems on these cars.
Old 07-06-2010, 01:32 PM
Seal77's Avatar
Well I blew my radiator up, just got it this last Thursday and went down the alley and BBBOOOOOMMM!! and then steam:
Blew the upper left side wide open.
Ordered a Northern All Pro 205062 this last Friday, and got it today. Hopefully the weather clears up this evening so i can install it.
Seal
PS: thats a '82 z28
Old 07-06-2010, 01:48 PM
the radiator was replaced 7 years ago. Is 7 years bad for a radiator?
Old 07-06-2010, 06:48 PM
microkid's Avatar
March 2011 ROTM
Technical User
not if its a cheap off the shelf auto part store one. i usually only get 2-3 years out of them before they crack, break, or blow out
Old 07-07-2010, 07:04 AM
blackz87's Avatar
How do you DESTROY a Radiator in that short period of time???????
Old 07-08-2010, 08:00 PM
microkid's Avatar
March 2011 ROTM
Technical User
lots of driving. i put 40k miles on my blazer in just a year. ive learned the hard way not to buy the cheapest parts availible. now if it has a lifetime warrenty, sure, ill buy it, and itll go back in 2 years when it goes bad
Quick Reply: radiator
