-   82-92 General (https://camaroforums.com/forum/82-92-general-10/)
-   -   quick trans question (https://camaroforums.com/forum/82-92-general-10/quick-trans-question-13950/)
1985RS May 5, 2007 12:54 AM
ok so i just pulled the t5 trans outta my car, and just had a couple quick questions. the electrical connector at the front left side of the trans is for the back up light correct? and the cable is for the tach or speedo? is the cable is for the speedo, where is the tach hookup or vice versa. thanks guys
nj85z28 May 7, 2007 11:20 PM
RE: quick trans question
the tach wire is hooked into the distributor. the cable is for the speedometer, and the wiring is for the backup lights
1985RS May 8, 2007 12:47 AM
excellent thanks, you dont know by chance where theoil pressure sender is located?
MadMikeZ28 May 8, 2007 01:04 AM
That would either be by the distributer or near the oil filter
1985RS May 8, 2007 01:09 AM
ok, the only reason i ask is beacause when i was pulling the v6 out, there were two connectors by the oil filter. one was connected to a cylinder that almost looks like a fuel filter and the other was connected to a fitting on the side of the filter housing, it confused me lol
