questions w/ tbi
Old Dec 3, 2006 | 08:37 PM
92camaroRS's Avatar
Default questions w/ tbi
hey guys some people told me that the stock tbi throttle body and tbi intake are big reasons that is keeping my LO3 from making good power. i didnt want to spend the money to switch over to carb. i was just wondering if i got a new edelbrock performer tbi intake and a new tbi throttle body, would that help out the flow a little more giving me some extra hp. i dont need a lot of horsepower but just something better than stock. if it would help me out how much hp would i gain with these mods. thanks a lot guys.
Old Dec 3, 2006 | 09:42 PM
SickSickSick's Avatar
Default RE: questions w/ tbi
actually the problem isn't in the throttle body or intake. it is in the heads. TBI engines have swirl port heads with 165cc intake runners and 1.84 valves. the truth of the matter is they just don't flow worth a crap. infact the only good use for tbi heads are as a boat anchor. 305HO heads flow pretty well if they are pocket ported, gasket match ported, and fitted with 1.94 valves. in my opinion your wasting your money upgrading the intake and throttle body. any gains would be minimal. Sick
FlufyTiger's Avatar
http://cgi.ebay.com/ebaymotors/1-Alu...QQcmdZViewItem
Get that and a dual plane intake, and you'll just need a bigger TBI unit, which can be found here:
http://www.turbocity.com/product_inf...roducts_id=142
and injectors:
Sorry I couldn't find the plate anywhere else, but there's so much crap to sift through on the internet when looking for something like this.
Old Dec 3, 2006 | 10:15 PM
MadMikeZ28's Avatar
You have to look out for how these will fit under the hood.
On my carbed 84 I had an Edelbrock intake which sat 1/4in higher and the stock air cleaner rubbed the hood insulation.
Old Dec 3, 2006 | 10:34 PM
92camaroRS's Avatar
hey thanks a lot guys, but if i did get the new intake and throttle body; also with the 14 in air cleaner i have now would that fit under my hood?
Old Dec 4, 2006 | 01:00 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
yes its a very common swap. you would just need the drop base air cleaner
Old Dec 4, 2006 | 01:31 AM
92camaroRS's Avatar
what exactly is a drop base air cleaner? is it any different than the holley 14 in. air cleaner i have now? thanks for the help guys
Old Dec 4, 2006 | 01:37 AM
MadMikeZ28's Avatar
You most likely have a drop base air cleaner if it is under your hood now. If you take the top off and look at the base on top the TBI it would have a dome shape instead of being flat.
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
