pulling steerng wheel Ignition help
Ignition help please. is it hard to remove the steering wheel from a 1990 rs camaro>? i lost the Only Ignition key i had to my wife car. now i need to get another ignition switch to put in.or how can i get another key made. we only had the one key.
dont count on it being that cheap. the 90 has the vats key, which will require ecm work or deactivation of the vats system if using a new key or chaning the cylinder. it is possible to deactivate the vats system, i think there is a write up on it here. now as far as removing the steering wheel, i dont think that is required to change the cylinder.
They could back in 92 but It would have to from the dealer the car came from. I do not think the dealer where required to keep that info more then 10 years. That was before large computer databases. But by all means check it out. They may have hade some system at GM that got upgraded since... I remember parts guys looking up paper files for Key code.
thanks for the help
i found the Key i dropped it at a shell station i visited saturday.i went in yesterday i asked the lady did someone turn in a GM key on a single key ring,the lady checked the draw and there it was. ((OMG)) i was like thank you..she said the lady saturday siad i dropped by the counter as i left some one picked it up and gave to her to hold on to.
now time to time find a place that can make a copy. can a lock smith do a copy.
thanks for the help
The dealer will charge a fortune for a new key.
Measure the resistance of the VAT on your key.
Find the appropriate range of resistance on E-Bay motors,
and you can get a key for a dime on the dollar.
Follow the instructions on the E-Bay page.
You can buy me a 6 pack later!
http://cgi.ebay.com/ebaymotors/1989-...item5636b85f78
