Project: killeRS
Old 07-24-2008, 12:19 PM
brassknukl's Avatar
Default RE: Project: killeRS
it ran with the cam in it and pump gas just fine before.
why would it be any different now?
  #42
Old 07-24-2008, 12:42 PM
ORIGINAL: brassknukl
8890462
also says h136 then h106on the other
and gm13 on both
Are you sure it's not 3890462? Can't find any such animal as 8890462.
3890462 are either 1966-67 327/350, 1.94 intake, 1.5 exhaust, 63 cc chamber or
1966-67 302/327, 2.02 intake, 1.6 exhaust, 63 cc chamber
h136 and h106 are the cast date, Months are stamped from A-L (January-December)
h=August, 10 & 13 is day of the month, 6=year, 1966
That would explain your lack of mounting holes, since they are pre-1968 heads as I earlier stated they might be.
Those heads are a small chamber, you'll definitely need to burn premium gas.
http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
  #43
Old 07-24-2008, 01:31 PM
MadMikeZ28's Avatar
You sure it ran fine? Test drive? Heared it? Hear say? To its full potential? My in-law bought a "good running" sb from mexicans. well they thought a cam with rounded lobes and dished lifters was a good runner.
  #44
Old 07-24-2008, 01:37 PM
MadMikeZ28's Avatar
It would not hurt to check with your machine shop connection for a set of heads with bigger chambers and accessori holes. It might cost you some cash with a trade for those heads. They may even be able to give the straight popp on how "sought after" they really are.
  #45
Old 07-25-2008, 10:35 AM
brassknukl's Avatar
by pump gas do you mean 87
or are you telling me i need racing fuel? this was a street engine originally
im really leaning toward just getting it in the car and starting it first.
  #46
Old 07-25-2008, 10:38 AM
brassknukl's Avatar
if after itsin the car itneeds the heads changed then ill do it.
i just want to see how it runs before i start changing things.
now im getting nervous about clearing the gear box in that 3rd gen.
initial measurements are kinda close.
but ill have a short water pump so i think itll just make it.
i hope[&:]
  #47
Old 07-25-2008, 10:44 AM
brassknukl's Avatar
ORIGINAL: Camaro 69
sorry its a 3
youre right
  #48
Old 07-26-2008, 04:06 PM
brassknukl's Avatar
got water and PS pumps attached
waiting for alternator
  #49
Old 07-26-2008, 07:37 PM
350rs's Avatar
March 2008 ROTM
ORIGINAL: Camaro 69
8890462
and gm13 on both
i dont mean to bump in and steal a thread, but i got a quick question. i have heads on my car that i cannot for the life of me fine a CC for. the numbers are 14102193. i know the intake and exhaust valve sizes, but i cannot find a CC rateing for them ANYWHERE. I wanna know so i can get a more accurate combustion ratio for my engine when its rebuilt. PM me or something if ya could. thanks.
  #50
Old 07-26-2008, 11:06 PM
OK, I'll try and put this here real quick before anyone notices!
Here's what I found:
65.3 c.c. combustion chamber
1.94" intake 1.50" exhaust valves
"This cylinder head is not a performance oriented head. It is classified as a high swirl head that was intendedfor good bottom end torque and fuel economy.The intake runner is restrictive because it has a rampcast into the bottom of the bowl to promote high swirl."
Quick Reply: Project: killeRS
