Power steering
Alright guys, I've got an 85 camaro, it doesn't have power steering. The guy before me had taken it out because he was able to gain some power. Now that I've had it for a bit, I'm wanting to put the ps back in because it's like driving a boat and it's hard to make tight turns or even park.
Does anyone know what the list of parts I need to put it back in?
Thanks!
Thanks!
well, it depends on what was removed. was it just the belt, or was the pump removed? are there still lines? if not, was the steering box hose fittings plugged? if they werent, and everything else is a no, you will need a p/s pump, belt, hoses, mounting bracket, and you should replace the box if it wasnt sealed as who knows what has gotten into it
