power steering
i was wondering if they make a electric power steering pump my problem is that i have an electric water pump and the heads i have on my 383 dont have the holes in them for my alternater and power steering to bolt to and my alternater is now been relocated to the driver side of the block below the water pump
i have never seen anything for gm with an electric power steering pump. i do know other manufacturers have them on stock vehicles, honda does as well as a few other imports. you could try to rig something up from them. you may also try to hack apart a hydroboost braking setup from a diesel truck. otherwise, i think you are s.o.l. without going to a belt driven water pump and fabbing up a bracket. now my question to you is, why do you want power steering on something that sounds like you are building to full race specs?
