PLEASE HELP ME!!!
Old Sep 24, 2006 | 12:00 AM
trailerparktrash2009's Avatar
Default PLEASE HELP ME!!!
I USED SOME KIND OF LIQUID GLASS TO SEAL MY HEAD GASKET..AND AFTER I PUT IT IN..IT TLD ME TO RUN IT FOR 5 MINUTES..SO I DID..THEN IT SAID TO LET THE ENGINE COOL AND FILL IT UP WITH WATER AND RUN IT FOR 15 MINTUES..WELL WHEN I I WAS DOING THAT ..THE CAR STARTED SMOKING ANDS SHUT OFF..I THOUGHT IT WAS CUZ I WAS OUTTA GAS so i went n bought sum gas then it wouldnt crank..it seems like the alternator is locked up or sumthing..can anyone please help me out???
Old Sep 24, 2006 | 12:30 AM
74454bb's Avatar
May 2007 ROTM
Default RE: PLEASE HELP ME!!!
Can you turn the motor by hand. if the alt is seized up the motor will still crank. if it's just the alt try some WD-40 on it just to get it to turn.
Old Sep 24, 2006 | 12:56 AM
ok..thanxx
Old Sep 24, 2006 | 01:42 AM
MadMikeZ28's Avatar
If you think you alt is seized pull the belt off and try to crank it.
Old Sep 24, 2006 | 01:54 AM
74454bb's Avatar
May 2007 ROTM
If it won't crank by hand then the motor seized up. Odds are with the bad head gasket,it was just a sign of other things gone wrong like a cracked block as well. what does the oil look like?
Old Sep 24, 2006 | 02:08 AM
the oil is really milky..the liquid i bought it suppose to permantly repair blown head gaskets cracked heads n blocks , intake gaskets, and other severe collant leaks (as it says on the diections that came with it)
Old Sep 24, 2006 | 04:29 AM
74454bb's Avatar
May 2007 ROTM
Can you turn the motor over? and did you run it with that milky water,I mean oil?
Old Sep 24, 2006 | 04:32 AM
for turning the motor over, it wont. i turn the manual fan on then when i go to start the car..i noticed the blade on the alternator gets hung up or something..and what i was going to do was use the liquid glass stuff using the milky oil then change the oil tomorrow..did i screw up?? and if so how can i fix this problem??
Old Sep 24, 2006 | 04:41 AM
74454bb's Avatar
May 2007 ROTM
By runnin the motor with the milky oil it may have seized the motor. if the alternator was seized the motor would still turn . Un hook the battery and reach down and try and turn the Crank Pulley by hand. if you can't turn it then it is most likely seized up,and time for a new motor. put the car in neutral first. then try and turn it by hand./with the parkin brake on just in case.
Old Sep 24, 2006 | 04:43 AM
these r the instructions that came with the gasket sealer
[IMG]local://upfiles/4041/3CF4433C660541C4B9A6FA9313513A08.jpg[/IMG]
