Plasti dip
Old Jan 30, 2013 | 04:19 PM
John4649's Avatar
Default Plasti dip
Have you guys ever heard of the product or had any experience with it ? It seems to have a really good outcome I haven't been ale to find any problems with it but was wanting some first hand experience.
https://www.dipyourcar.com/home.php
Their are tons of videos of it being used
Old Jan 30, 2013 | 05:09 PM
BasicConcepts's Avatar
Technical User
plasti dip is great, best part is if you decide you hate it you just peel it off. what are you planning on painting?
Old Jan 30, 2013 | 06:08 PM
John4649's Avatar
My camaro in the monster green or the fire belly orange
Old Jan 30, 2013 | 08:29 PM
Technical User
good luck bro, ive seen a couple people do it and it looks pretty good. post up some before and after pics.
Old Jan 31, 2013 | 12:58 AM
John4649's Avatar
I'm going to do a test on a small area first to see how it comes out but it will be a while I tore my shoulder again and need surgery again
Old Jan 31, 2013 | 03:01 AM
Camambro's Avatar
April 2012 ROTM
I painted the roof of my old camaro with black plasti dip cause the paint was pealing. It came out pretty good.
Old Jan 31, 2013 | 12:00 PM
John4649's Avatar
@Camambro how hard was it use it and would you use it again? If and when my car gets done and we like the outcome we will also do the 02 dakota and the f350
Old Feb 1, 2013 | 06:26 AM
Camambro's Avatar
April 2012 ROTM
It's pretty easy to use and it doesn't look bad but I wouldn't do it as a permanent solution though.
Old Feb 1, 2013 | 06:59 AM
I did my head light area and my rims on my 4th gen. The Dip has held up on the rims better then paint would have.
Make sure you either clay the paint or use a wax remover before you apply it. The car must be clean. If you have to tape anything off then before you remove the tape run a razor along the edge of the tape. If you do not cut the edge the tape can lift the dip when you pull it off. Once you think you have enough coverage do one more coat. The thicker the dip the easier it is to remove. 3 hvy coats does a nice job for me. I have never had a problems removing off a surface and when I researched it I did not find anyone who had a problem removing it.
Old Feb 3, 2013 | 10:35 PM
Paul86iroc's Avatar
Plastidip is great I did my wheels black. Came out fantastic.
