Performace
This summer I plan to buy an 1988-1992 Camaro.. All the ones I found have a 305.. Can I drop in a 350 and keep the rest stock? Or do I have to do modifications? If I choose to keep the 305 what can i do performance wise? Thank you very much
RE: Performace
the 305's CAN be made quick. a member (sicksicksick) has a 305 in the 12s, but hehas stripped that thing to the bones i believe. if you want to go the easy and lesser-headache route you want to find a car with a 350 already in it. the swaps are possible, and reletively easy as far as motor swaps go, but thats a major job. if you go carbed 350 the swap is pretty straight foreward
RE: Performace
A carbed 350 swap is the easiest way to go.
Yes if you swap the motor the rest can remain stock. Everything off a 305 can be put on the 350. |
RE: Performace
maybe as far as accessories go. but the 305's and 350's have different intake manifolds.
RE: Performace
ORIGINAL: SpecterGT260 maybe as far as accessories go. but the 305's and 350's have different intake manifolds. An engine swap in and of itsself is not that hard. Give yourself a full day to tear the motor down, another morning to pull it out, another afternoon to drop new engine into the bay and about 2 full days to carefully hook everything all back up, check and double check, and finally fire her up. Please please please, make your life easier and buy a super long 3/8' extension to loosen/tighten the motor to bellhousing bolts. Those bastages took me about 2 hours to take out on my first swap.......took me 15 minutes with the long extension..... |
RE: Performace
305 is carb, 350 is tpi in the years he listed.
RE: Performace
depends on what you want to do, if you want a drag car, then strip the entire car. all wires and everything, start with just a roller with nothing in it, and build it from there.
or if you want a street car with some zing to it, then take the 305 and junk it and slap in a 350, you will have some xtra wires left if its a throttle body engine, but a 350 in one of these is pretty potent, even a lower hp |
