OK i made up my mind and now have a few questions
I feel like ive been leading you guys on , on so many things like : im going to get a 79 or a 91 or a 84 camaro and i havent yet, but made up my mind that im going to get the 91 ive been talking about for sure this weekend. here are the questions i have.
1. does the 91 camaro RS 3.1 v6 have a V.A.T.S system in it ?
2. I want to change it to a carbed 400 small block, if i install the 400 small block will the camaro's VATS system keep it from running?
3. if the camaro has a VATS system, how would i bypass it or remove it if i need to?
4. will all the dash components work ( speedo, tach, turn signals, dash lights) after i install the 400 s.b.
5. when installing the 400 small block, What wiring if any will i have to replace for a good conversion.
6. i plan on chagning it to a mechanical fuel pump. can i put in a gas tank from lets say a 82-87 carbed camaro to make it easier, or will the hookups from the 91 gas tank work just fine?
7. After the conversion, is there anything that i have to watch out as far as the computer , or will that be disabled after i convert it to the carbed 400 small block.
LAST BUT NOT LEAST
8. Ive been pondering on what transmission to put in the car, thinking a turbo 350 or 400. whats your opinion on a good transmission.
thanks for all the help and i appreciate it .
LAST BUT NOT LEAST
RE: OK i made up my mind and now have a few questions
