noise in front of car
1991 camaro z28. There's noise coming from the front of my car when I hit the gas and Start movng. When I take my foot off the gas and the car still moves the noise goes away. It's like a whirl sound that gets faster as the car goes faster then when I let off the gas it goes away.it.sounds as if the noise is coming from the engine area. What could this be Thanks for the help
Wayne |
is the noise dependent on engine speed? might be an accessory item is going bad. a water pump can make a whir until it totally fails. take it to a shop if you can't fix it yourself
Check your alternator.
