new to this=help
Old 02-23-2006 | 11:56 PM
blksiryder's Avatar
Default new to this=help
ok i'm looking to get a 1993 rs can anyone tell me how hard and what i would need to swap to a 305 or 350 what ever is easier.i have been working on hondas all my life and i know what will go where and what it will take to get it there. for the swap i need to know ecu swaps wire swaps tranny swap. or even if i can put a 3.8 on a auto tranny. thank you for all the help and glad to be among the family.
Old 02-24-2006 | 06:53 AM
89/383stroker's Avatar
Default RE: new to this=help
hey welcome but i think the you should save youself some time, money, and bulls*** and just buy a z28
Old 02-25-2006 | 06:13 PM
If u want a v8 and you don't have a car yet, go ahead and get a v8 from the start. By the time you get all the parts for a v6 to v8 swap it will cost you more than getting a v8 car. Changing a 3.4 v6 for 3.8 v6 is really not worth the effort and just as much work as swapping for a v8.
Old 02-25-2006 | 07:50 PM
331pony's Avatar
its not that bad all u realy need is mounts, trans cross member, drive shaft rear end and pretty much new suspension (or get thwn out of a junk yard like me) u will save alot of money buying a used engine and rebuilding it yourself. and if i were you i would go with carb but thats me.
Old 02-26-2006 | 02:20 AM
blksiryder's Avatar
well i just got a 1992 v6. cheap. i may just leave it the wat it is and build my own turbo or just put a 305 into it. i just will need help to do the wiring for the efi.
but from import to detroit. the force is strong with me.
Old 02-27-2006 | 02:16 AM
vortec350s10's Avatar
I'd just spend the extra money and get a z28. you'll spend a lot more getting a cheap v6 car and doing a swap than if you just bought one with a stock v8. Plus z28's have better suspension, usually rear discs and posi, plus bigger swaybars and a quicker ratio steering box. Plus it will probably run better too since it's all stock and intended to work with everything. A v6 car will usually have a lower geared rear end. And you'll need a new/ different transmission. I've done engine swaps and although they can be fun, if you can get a car with the engine you want, just get it. Just my 3 cents.
