Need interchange info
Old 05-26-2011, 11:20 AM
1989_RALLYSPORT's Avatar
Default Need interchange info
ok i have 89 cam it had 2.73 ratio before now it has 3.73 ratio
my spedo gears were junk irregardless i need interchange info as to what s10s camaros and fullsize trucks that have mechanical spedos so i can go get the gears i need
thanks...oh btw... anyone got pics o home made belt tensioner setups?
i got rid of the whole left side bracketry with ac and smog and now planning to take factory tensioner and making a bracket for it to mount to the block alone
Old 05-26-2011, 01:22 PM
carguy68ssrs's Avatar
Make SURE you keep everything turning in the right direction when you set that up
Old 05-26-2011, 06:25 PM
microkid's Avatar
March 2011 ROTM
Technical User
the s10 ratio might be close if you get them from a 2wd. otherwise they wont be accurate for your tire size. and good luck with removing them with a serp belt, you will need delete pullies for everything to work correctly
Old 05-27-2011, 07:52 AM
djs383's Avatar
As far as the trans/speedo gears. Just order new ones, they are not expensive, and if you input the right data, you will end up with the right gears. Note there are two styles of driven gears because of a gear housing change. Just get the right housing/gear set up and you'll be fine.
As far as the pulley set up goes, leave the air injection pump alone. It costs you no power loss and that way you aren't messing with that pattern. If you absolutely insist on removing it, purchase the delete pulley.
Old 05-28-2011, 02:34 PM
cant find spedo gear sets for under $50 plus shipping....when i can get some used ones for $5 plus gas
i know the 2wd 6cyl and 4 cyl s10 trucks have 3.73
most 4wd and awd s10s do too but i just want more options to look through and find the newest year possible that has the right ratio
Old 05-28-2011, 02:38 PM
oh and as for the serp. setup its not a factory motor all i have is alternator and water pump... no power steering ive modified a manual gearbox from a truck into my car turns just as easy as power steering did
i plan on having an idler pulley and a tensioner pulley both will be the 4 inch tensioner pulleys
meh ill figure it out.. it wont be the first time ive done this i made my own setup on my 86 turbo'd roller 2.8L fiero gt
Old 05-28-2011, 02:39 PM
once the cAR is all done, driving and tuned in. then ill make a thread of what i did.. i probably have a couple hundred pics of my progress
Old 05-28-2011, 05:46 PM
djs383's Avatar
Ok, well if you are going to go the cheap route, at least look up what color you should have and try to find that one. Keep in mind, you may not be able to get even within ten MPH unless you do both the drive and driven gear. Do things the right way so you don't have issues later on.
I still don't understand your belt question, if its only a water pump and an alternator, why is not a Vbelt set up?
Old 05-28-2011, 07:01 PM
VBELT sucks
lol idk i like my stuff to be unique so i usually do alot of odd customizing
i know which color gears i need but dont want to just go tearing every 700r4 i see apart for the right gears
im not trying to go cheap route but i am low on funds and verry low on time cannot wait for part to be shipped
Old 05-28-2011, 07:03 PM
my belt question was if anyone else has done a custom setup them selves so i can get an i dea as to how i want to do my bracketry for idler pulley and tensioner pulley.. plan on going with a verry short serpentine belt
Quick Reply: Need interchange info
