Need help
I have a. 92 Camaro rs. With 3.1 The car will start as long as gas is being sprayed in intake. It has a new fuel pump. My question is what order should I check the electrical to see why the injectors are not coming on. I have replaced the computer. Just don't want to keep replacing things if I can test them. All help is appreciated.
Actually, the very first thing you should do, which is fast and free, is to verify that you have fuel to the injectors. A simple push of the shrader valve on the fuel rail will tell you whether or not you have fuel, and with good pressure. Having a new fuel pump doesn't mean anything.
