NEED ADVICE ON BUY ASAP
Old 03-24-2008, 09:56 AM
carguy_z28's Avatar
Default RE: NEED ADVICE ON BUY ASAP
It depends on where you go, how much the car is worth. In some provences here in Canada, a 2002 SS Convert will sell for 35000 easy... and we buy them in the states for 13500 every month or two... As stated, its only worth what someone will pay for it. If the car is in good shape, engine and tranny and interior are all exeptional shape, then 5 g's is not a bad price... You may be able to find one cheaper, but it may not be in as good of a shape as that one... I have a 1990 Iroc that I bought for 6500, In canada thats pretty cheap for that car... In the U.S. I wouldnt have payed more than 5 for it, even in the great shape its in...
Old 03-24-2008, 05:31 PM
gvmv's Avatar
ORIGINAL: s281er238
THE OWNER IS ONE OWNER HIS A ENGINEER AND HE REPLACED ALL THE PARTS ANT TOOK CARE FOR ENGINE MINT SHAPE HAS ALL THE PAPER AND ALL .THE ONLY THING I FOUND IS THERE IS A NOCK COMMING FORM THE INSIDE OF THE CAR WHEN YOUR SITING IN IT AND YOU GAS THE SOUND GOES ALONG WITH THE GAS IT WHEN RPM GOES UP IT WILL SPEED UP BUT I LISTEN IT SAND SOUND LIKE THE INJECTORS ARE MAKING THAT NOISE SOUNDS KINDA LIKE BAD EXHAUST SOUND I DON'T KNOW HOW TO EXPLAIN IT BUT NOTING LIKE A BAD RING OR PINION OR LIFTERS ANY IDEA WHAT THAT IS I FEELS LIKE THE INJECTORS ARE MAKING THAT SOUND AS FAR AS ENGINE DO THEY GIVE ANY PROBLEM AND BREAK DOWN EARLY OR THERE PRETTY RELIABLE I'M MEAN THIS GUY REALLY TOOK CARE OF IT THANKS SO MUCH FOR YOUR HELP NA D RESPOND THE SOUND COMMON FROM THE ENGINE IS LIKE A EXHAUST GASKET LEAK SOUND IF THAT HELPS BUT THE MECHANIC AT CHEVY SEED NOT FROM THE ENGINE
There is this key on your keyboard that is called caps lock. Along with periods and returns. This would make your post much easier to read, since I am not reading it in this format. A correctly and nicely formated post will get replies faster.
Old 03-24-2008, 05:58 PM
s281er238's Avatar
hahaha lol sorry about that lol .how is the gas millage on these cars
Old 03-24-2008, 09:05 PM
gvmv's Avatar
ORIGINAL: s281er238
Varies by driver, EPA is 17-20 auto 17-22 manual I do believe.
Old 03-25-2008, 06:17 PM
84 z .....'s Avatar
mine is apprased at $9000 but there's tons of parts there that aint stock
WTFCamaroProblem
2010+ V6 Tech
12
01-05-2014 11:14 AM
rcknrolfender79
10-11-2009 07:41 PM
rcknrolfender79
10-08-2009 09:13 PM
cjoelmitchell
08-23-2009 11:00 PM
Quick Reply: NEED ADVICE ON BUY ASAP
