Mystery electronics
Old Dec 22, 2006 | 12:36 PM
camarohelp's Avatar
Default Mystery electronics
In replacing the heater core over the past few days (which, by the way, was a hoot, let me tell you) I removed a strange little doohicky from the passenger side footspace. It was located just right of the footspace, against the wall of the car, covered by carpet, and connected to the plastic red interior trim. Now the problem is that there is a four-pin connector coming out of one end and something like ten of the twenty or so screws that secure the cover and the contents are covered in some sort of factory glue, so rather than take it apart I was wondering if anyone here can tell me what the hell it is and whether the fact that it was never plugged in was a problem...
I also have a similar box on the drivers side, and it is also unplugged.
Thanks!
Old Dec 22, 2006 | 11:26 PM
MadMikeZ28's Avatar
Default RE: Mystery electronics
It is the doohicky that controls the whatchmacallit. Was it mounted over yonder? If yes then it is the whatshisface. Do you have the optional Thingamajigger? They usualy have two whatthe****isthis.
Mystery solved!
Old Dec 23, 2006 | 01:23 AM
Dan88IROC Z's Avatar
Pics.
Old Dec 29, 2006 | 04:13 PM
camarohelp's Avatar
Thanks for the help but
They seem to be factory speakers, most likely with amps. How to connect themto an aftermarket radio, however, is beyond me.
Comanro
Aug 6, 2014 06:09 PM
tattoo400
Aug 22, 2012 11:36 PM
electronics84
Sep 9, 2009 08:45 AM
carlsbadlt1
Nov 17, 2005 12:57 AM
