my new camaro
i recently bought a 88 camaro for 1600 with a v-8. i beleive its a 5.7 ltr but not for sure. the car needs some work done but all in all a good running car. except after I drive it around for a while, it will start cutting out, like im out of gas. the motor is tbi and it has an awkward looking spoiler on the back. smaller then the iroc & z28. can anyone help me and tell me more about my motor?
also it only says camaro on the rear bumper, no pwr windows and registers 115.
well i just went out there and moved it for some pictures, and when i turned it off a little white smoke came out from the xaust. and a screw is out on the top of my valve cover, and a little smoke was coming out of it. i just topped it off with some oil treatment also. is this just from a need of an oil change?
It could be, how low was your oil? I would get a new valve cover gasket and a new bolt for it. Oil can steam, but it seems like some is getting burnt. Make sure your antifreeze is full because there could be a coolant leak. White is USUALLY antifreeze/water and a slight blueish haze is oil and black smoke is too much fuel.
Replace the fuel filter. It's likely never been done before, and it probably should be anyway. And don't buy a fram, or purolator. Fuel filters are cheap, but you should still do the rest of the tune up, as well as check for coolant leaks into the oiling system.
