my car, 87 camaro
well i got a question ive been diein for someone to tell me. i have a 3rd generation camaro, that i wanted to put true dual 3 inch exhaust on, and have come out before the back tire. does anyone know if the 3rd gneration camaro has room for true duals?
If you dont mind the sound of them scrapping the ground. I have Eibach springs on mine and there is no way I could put true duals on mine. unfortunatly the real problem is where to put the mufflers. The factory exhaust pipe runs next to your drive shaft so it will clear the ground. If you tried 2" pipe you might have a little more luck. I have yet to see it done yet. You would probably have to do some modifications to your floor pams to make it work correctly.
