lt1 swap?
can an lt1 bolt up to the stock mounts in an 88 irocz it already has a 89 corvette motor in it but i wanted to upgrade is there anything special i have to do or is it pretty simple?
RE: lt1 swap?
Well I wouldn't think it would be too hard, because isn't the L98 the older brother of the LT1?
RE: lt1 swap?
Are you going to keep the LT1 fuel injection? If you do you will need the LT1 PCM to go with it.
RE: lt1 swap?
ok and the six speed should bolt up too right? any modification for that?
| All times are GMT -5. The time now is 09:23 AM. |
