looking for sub frame connector, wonder bar,& strut support pics and dimensions
im looking for some detailed close up views of sub frame connectors from multiple directions of view.
also wouldnt mind the dimensions and pictures of the wonder bar and same for the strut support bar im looking to make my own and any information and or measurements would be greatly appreciated |
bump~~~~
why not get under the car and make some measurements of your own?
i dont know where the wonder bar goes.
i know where the sub frames are but would like to see other SFCs before i make some.. i more or less want to see how people have attached them and if there should be a cross member between the two SFCs and as for the strut tower support bar... i want to see different ones to see how people have made them adjustable to lengthen and shorten them... and how they have attached them. i dont want mine permanently mounted as i will be doing an engine swap later on. :icon_wcam: |
making the strut bar adjustable is easy. in a since. cut a chunk out of the center and weld in something like a tie rod adjuster sleeve. Obviously make it look better and more solid than that, but thats the idea. Attach it to the three bolts holding he strut mounts on the car. Make it a T shape to attach to the cowel or the firewall for a little extra support. However make the bottom part of the T more of a V. Everybody knows that shape is good and strong.
wonder bar attaches between the steering box and frame rail. then exact opposite of that. |
