A little help please!
Old Jun 17, 2008 | 06:55 PM
BlueKitsune's Avatar
Default A little help please!
Ok I have 2 questions. First is what would happen if I removed my smog/air system and is it worth it?? (305 TBI)Second is how does the cruse controll work becuase right now I cant get it to do anything. Thanks for the help!
Old Jun 17, 2008 | 08:19 PM
350rs's Avatar
March 2008 ROTM
Default RE: A little help please!
First question.. NOTHING, leave it. you need it to pass emissions, and even if you dont need to anymore.. its really not hurting you.
Old Jun 17, 2008 | 08:37 PM
black89rs's Avatar
do you know how it works as far as the directional handle??
Old Jun 17, 2008 | 11:04 PM
black89rs's Avatar
YOU SHOULD HAVE A SLIDE SWITCH ON THE END OF YOUR HANDLE...ONE WAY IT SPRINGS BACK AND THE OTHER IT STAYS SOLID ..YOU SHOULD ALSO HAVE A BUTTON ON THE VERY TIP OF THE HANDLE. IF IM NOT MISTAKEN SLIDE THE SWITCH TOWARDS THE DOOR..HOLD IT THERE AND PUSH THE BUTTON AT THE SPEED YOU WANT
Old Jun 18, 2008 | 12:45 AM
musicman2.0's Avatar
smog parts aren't hurting you. Not sure on the cruise, I think it's vacuum operated, might have a leak.
Old Jun 18, 2008 | 01:43 AM
@ black89rs NO CAPS LOCK IS THE CRUSE CONTROL TO COOLNES ****NUT
@ musicman2.0 Thank you for being helpfull unlike other idiots. And I did figure out its vacuum but I can't find any leaks in the system. Is there a relay or a fuse for it aswell?
Old Jun 18, 2008 | 01:47 AM
It's hard for me to say, I'm just relying on general knowledge. I think there's a fuse for it, give that a check.
Old Jun 18, 2008 | 01:48 AM
how long has it been since the cruise was used? It might be stuck.
Old Jun 18, 2008 | 01:50 AM
I've looked I cant find a fuse in the fuse box for it. Isn't there a fuse box inside the engine bay aswell? My luck the entire cruse control system is dead.
Old Jun 18, 2008 | 02:01 AM
Do you have a little vacuum for bleeding brakes? If you do, take the line off the bellows, and attach your vacuum. Does it move the throttle? if not, this might be the problem.
