Last bit of help needed
Ok Well I have all the engine work done, its timed and fixed up properly.
Now to fix the other stuff
At all speeds it feels almost like its pulsing, Im not sure how to describe it at all, its alot like a vibration and I already figured out its not engine and I think its not the transmission. Any ideas?
Second my car even when warm idles very high, around 1750 RPM over 2K when cold Any ideas? I did rebuild when I put the new intake on, Think the idle set screw may need adjusted?
Finally, I have a slight vibration in the steering wheel, idk if its related to the first problem buts its kinda freaky, along with the steering feels extremely over sensitive. Alignment may be needed?
Thanks Everyone!
Thanks Everyone!
Idles fixed, leaking EGR Valve. All engine work done. Tho I have a question. How do "burp" the engine? Coolant of course
The vibration I thins is all in the front end tho I have a strange feeling my transmission may be shot
for the coolant just fill the system up and leave the radiator cap off. fire up the engine and when the thermostat opens up it will gush out coolant. just fill it back up while the car is still running and put the cap on and you are done
datboypatrick954
13
03-20-2009 09:07 PM
