IROC Z Transmission
How did you connect the torque are brackets? is the drive shaft the same length, and what about speedo? X-member?
there all the same.the only thing u really have to do is get the torque arm mount from a stick becuz the auto is reversed.(the stick groves look like this (3) and the auto is (E) the t5 is the same length as the 700. and everything else is just a direct swap. if urs a a 90-92 u need to get an eletric spedo adapter.
dsinclair999
02-21-2011 11:24 AM
