IROC wheel tire size
Old Jan 24, 2008 | 04:59 PM
350rs's Avatar
March 2008 ROTM
Default IROC wheel tire size
I happened across a set of 4 IROC wheels with 3 brand new tires for 100 bucks. three of the wheels are in really good shape, the one i will need to replace though. But still, couldnt pass up the deal for 100 bucks!!
anyway, my question is whats the minimum and maximum size tire i could put on the REAR wheels? im gona stick with the 245's up front, but i want wider in the rear, i was thinkin a 255 or even higher if its possible.
Old Jan 24, 2008 | 05:15 PM
blackz87's Avatar
Default RE: IROC wheel tire size
Stock IROC-Z Wheel size is 16x8(marked front & rear due to the different offsets) and used tire size 245/50/16 front and rear. Max recommended size is 255/50/16.
Old Jan 24, 2008 | 05:20 PM
MadMikeZ28's Avatar
255 was what I used in the rear. But if you want to research tire sizes
http://www.1010tires.com/TireSizeCalculator.asp
Old Jan 24, 2008 | 06:49 PM
350rs's Avatar
March 2008 ROTM
ok, looks like a 255 is what im gona be getting since i cant rotate them anyway.. thanks.
Old Jan 25, 2008 | 07:38 PM
EddieTheRipper's Avatar
you know whats totally ****ed a friend of mine put 295's on the rear and amazing enough they didnt rub, now i dont know if he used spacers or not but wow, i was amazed the sidewall came from the bead and out about a inch..nuts.
Old Jan 25, 2008 | 08:42 PM
350rs's Avatar
March 2008 ROTM
yea, i dont want that to much. the less the better.
tims78camaro
Jan 9, 2013 06:29 PM
zg79berlinetta
70-81 V8 Tech
Jul 10, 2011 03:21 PM
evelknebel
Jul 25, 2010 12:02 PM
bigpat
82-92 V8 Tech
Mar 24, 2009 10:19 AM
JordonZ28
Dec 12, 2007 11:23 AM
