Idle problems
I have a 91 camaro rs that I have swapped to a vortec carb. The car runs pretty good. The other day I was driviing home from work, and half way home, i realized it was not ideling normall. It normally idles at 1050 rpm. It was down to around 600, and wanting to die at red-lights. I got home and let it sit for a while. I went to crank it up, and it will only stay running if i keep it rev-ed up. Any idea what this could be? Here's a list of everything new on the car:
New vortec heads
Performer Intake
600 cfm edlebrock carb
accel super coil
accel distributor
plugs
plug wires
alternator
water pump
battery
griffen radiator
2 electric fans
fuel pump
fuel pressure regulator
New vortec heads
Performer Intake
accel super coil
accel distributor
plugs
plug wires
alternator
water pump
battery
griffen radiator
2 electric fans
fuel pump
Well, everything looked normal on the idle adjustment. I even tried to adjust on it but could not get the car to stay running during idle. Guess i got some more playing to do. Ideas always welcome and thank you. I'll play some more with it tonite.
