Hey biznitches, Im baaaaack! Need help!
#24
Ill look into that, but I really think its my cheap a$$ headers. I put them on the original 305. They were ebay bargains, I think they were some Summit universal fitment kit. I wanted to go as cheap as possible because I had no intention of keeping the car..well here I am 4 years later!
Im going to try some venting ideas in the meantime....
#25
#29
I wrapped the headers today. What a joyous event THAT was. Did you know there are a few spots that cannot be reached on those headers while they are in the car? Therefore, I have a few gaps around the collector area. Man they smoked like a mofrugger for the first 15 minutes. Ill be taking her out in a few minutes to see if there is any difference. Ill let yall know.....
#30
I wrapped the headers, poorly I might add. The wrap did very little. I still vapor locked, only it took about 5 minutes longer this time. Im going to check the temp guages tomo and probably install an aftermarket temp guage. Then Im going to relocate the fuel line (but where can I run it up the pass side thats not close to the header?) Ive also got a fuel cooler but the fittings are AN type and nobody here sells that stuff.
I think that when this is all said and done, Ill be needing a bigger radiator....boooooo!!!
