Help Trunk locked
Help Trunk locked
Hey guys im new to this forum and i need alittle help. well i was cleaning my trunk one day and i think i left my door key on the lip of my trunk and shut it. well now i can't open it to see if my key is there do you have any advice on how to open a trunk with no key?. i have access to the inside but not the trunk please help thanks in advance.
RE: Help Trunk locked
a medium sized hammer contacting that glass at a high rate of speed aughta do the trick!
but in all seriousness. is it a electric pull down type or the manual? i assume its the manual tupe. in which case you might have to call a locksmith OR risk damaging something
I know i thought of that but it is an electronic pulldown. is there a way that i can put power to the lock somehow and open it or take off the plastic around it and hit a lever there has to be a way instead of anger management.
ORIGINAL: black89rs
hey mike he said he left it on the lip
Then if a key is sitting on the lip that is easy. If its on the edge of the plastis inside then he should still be able to climb in the back and fish with a screw driver or something flat. If its on the metal outside the rubber seal then he should be able to see it on the sides or if its above the tail lights fish it out from there with a bent coat hanger or flush with water.
Oh and 350RS. You are starting to sound like ScottD!
