help! passkey theft problem
92 camaro , aniversary , 305
Im hoping someone may have experience with GM's pain in the butt pass key system - it has shut down my 92 camaro. The only way I can start is to disconect the battery, then connect it beck up, I then hear a relay click and I can start it. I can turn it off and it will restart as long as I dont keep it off for more tha approx. 4 minutes or so. After 4 or 5 minutes, it start its beeping and parking lights flash. I have tried leaving ithe igition on for 10 minutesm thinking that it might have to rellearn - but no luck
Any Ideas???????
Thanks snick
Any Ideas???????
Thanks snick
Since your new I will fill ya in. You only need to post this once. Its not an engine issue so in this section is enough. People will see it.
GM's so called pain in thebutt does not flash lights or beep. It sounds as if you have an aftermarket alarm on the fritz. Find the alarm and get rid of it! Its an issue I ahve seen with many aftermarket alarms. Even with the ones installed by the dealers.
