help me with my 92 rs please im out of ideas
Old Jun 5, 2009 | 12:47 PM
littlereiter99's Avatar
its started and drove for about a mile then died ( had to have my buddy tow it back to my house) we tried grounding the coil before we started it in the morning and it didnt even spark but then put it back together and it started (ran for a whole mile then died couldnt get it started again) give me all and \any input i dont know where to go from here and i need my car to get back and forth to work to thanks guys
Derek
Old Jun 5, 2009 | 12:49 PM
and also as for rebuilding the tb i have no idea how to do that and is it going to cost money cause im broke right now?
Old Jun 5, 2009 | 01:12 PM
we also tried putting a little gas into the tb but still nothing starting to belive its a electrical problem but what kind of electrical problem would cause it to run for about a mile and then just die and not start thanks
Derek
Old Jun 5, 2009 | 01:50 PM
ignition modual or coil.
Old Jun 5, 2009 | 01:59 PM
camarohelp's Avatar
Does the car turn over when it won't start? If the battery is not dead, the car does not turn over or make a *click* when you try to start, and the word SECURITY lights up in the gauge cluster, the problem is indeed electrical, with the VATS.
If this is the case, the metal contacts on the small pellet in your key should be cleaned and maybe lightly sanded to remove possible corrosion. This may fix the problem, although if you have it as bad as I did, the problem will be somewhere further down in the system, and you'll need to get a new PROM with VATS disabled.
Old Jun 5, 2009 | 03:37 PM
alright guys heres a link to a video of me trying to start it maybe this will help
http://s366.photobucket.com/albums/o...t=MOV00486.flv
Old Jun 5, 2009 | 03:59 PM
did u scann it for trouble codes. not that hard. we could go though all the things it could be and it could cost some major coin. could be bad wire somewhere, ignition modual, coil, opti, maf, tps, iac, 02 sensors, fuse, oil pressure sensor, plugs, plug wires, coil wire, ecu. the tach is not moving so i am thinking ignition modual, opti or coil.
Old Jun 5, 2009 | 04:22 PM
its not the coil i took my buddys 89 silverado a and it still wouldnt start and i know thats good because his truck runs perfect but is there anyway to know if its the ignition module and where is it located
Old Jun 5, 2009 | 04:23 PM
no didnt scan for trouble codes where is the tech section on here im new and have no idea where it is
Old Jun 5, 2009 | 04:31 PM
  #20
or how do i scan for codes without doing it the expensive way (taking it to a shop)
