Heater Core replacment ????
Chilton Says:
Removal:
1. Drain Cooling system
2. Remove both heater hoses
3. Remove lower right hush panel
4. Remove lower right instrument panel and the ESC module if necessary
5. Remove lower right "panel-to-cowl" screw
6. Remove heater case screws
7. Remove the case cover
8. Remove the support plate and baffle screws
9. Remove the heater core and baffle plate from the housing.
Do you need installation?
Removal:
I've done it in my 69 RS and other cars in general. I think it's not going to be as simple as the 69 and am expecting to have to take the whole dash out from what I've heard. Thought someone might have a good weblink to check out.
Thanks!!
Thanks!!
nope not so lucky, to access it you DO have to take out the whole dash pretty much. I need to do mine. its ghetto rigged right now since its summer, but i need to replace it by winter. Ill let ya know how it goes.
ORIGINAL: 350rs
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
