Headlight Question??
Old Aug 16, 2006 | 09:25 AM
trailerparktrash2009's Avatar
Default Headlight Question??
my drivers side low beam light is out..how do i take it out to replace it??
Old Aug 16, 2006 | 02:17 PM
Camaro_Kid's Avatar
Default RE: Headlight Question??
I just replaced 2 of mine and it was pretty simple. First I unplugged it in back, then I took out the screws on the top of the light. The screws under the light were kinda tricky because I had to kindof push down on the plastic by the light to be able to get to them with the screw driver. Once you get the bottom ones loosened dont completely remove them because there are little slits in the light frame so all you have to do is pull up on the frame to get it out. Once you do all this, you slide in your new light. One problem I found was the screws were a little rusted and really hard to get out at first, so I sprayed on some WD40 and they came out pretty easy. Hope that helps....
Old Aug 17, 2006 | 07:15 AM
thanks alot...
Shooterrobb
Apr 25, 2014 05:33 AM
Cesko81
Jul 28, 2011 07:18 PM
Gorn
Jan 6, 2011 02:25 AM
Butch67
67-69 V8 Tech
Oct 12, 2010 07:24 PM
Butch67
Oct 12, 2010 07:17 PM
